GarageSale 10 Beta 12 Released
GarageSale 10 Beta 12 is available for download from this URL:
https://downloads.iwascoding.com/downloads/GarageSale_10.0b12.dmg
What’s new in Beta 12
  • switched to a new eBay API for uploading listing images to eBay’s Picture service (the API used by GS 9 is supposedly turned off in September)
  • fixed cosmetic glitch in Attributes panel for certain attribute types (eg. DVD > Region Code)
  • tweaked “package type” fix from Beta 10 to prevent unwanted eBay warnings in certain scenarios
What’s new in Beta 11
  • AI Generator window can be invoked for listings that are already running
  • Apple Script: store categories can be queried (see example script)
  • Apple Script: added ‘remove all item specifics from’ command (see example script)
  • Apple Script: added ‘add required item specifics to’ command (see example script)
  • Apple Script: added ‘add suggested item specifics to’ command (see example script)
  • Apple Script: fixed errors when trying to change a listing immediately that was just duplicated
  • updated French and Italian localizations
  • crash fixes
What’s new in Beta 10
  • always send the package type to eBay when staring listings, so shipping profiles using calculated shipping don’t fail with “Package Type is missing”
What’s new in Beta 9
  • styled text can be pasted into the attributes in the Preview (formatting is not yet removed)
What’s new in Beta 8
  • Variations panel: adopted new eBay API to make “Update Remaining Quantities” button work with listing with more than 200 variations
  • Orders section: adopted a new eBay API to download a buyer’s registration address (may only work in specific countries)
  • Scheduler Groups: listings removed from a scheduler group that’s currently processing aren’t started
  • Scheduler Groups: changes to launch interval and start times are applied to already running upload operations
  • Scheduler Groups: when deactivating a group with pending listings, yet unlisted listings aren’t started
  • Scheduler Groups: GarageSale no longer hangs when erasing interval field
  • Scheduler Groups: added ‘seconds’ label to interval field
  • updated GarageSale Icon Legend
  • added “Item Overview” print template to Print Pick List menu
  • updated Localizations (not fully complete yet)
What’s new in Beta 7
  • added more logging to track down specific issues
What’s new in Beta 6
  • fixed a bug, that when pasting images into multiple listings at once, could cause errors when executing some AppleScripts later on
  • GarageSale’s application icon of beta version contain “Beta” marker once again
What’s new in Beta 5
  • added “Print Pick List” feature to Listing section (like Packing Slips for orders, but for listings)
What’s new in Beta 4
What’s new in Beta 3
  • new application and document icons
  • new preferences setting: “Outline View: Show Recursive Item Count”
What’s new in Beta 2
  • Orders section: users can increase thumbnail size in the item table via context menu
  • some tweaks to ‘Send Offer To Buyers’ window positioning
  • uses new eBay API for downloading certain category attributes
What’s new in GarageSale 10
Kristian, Paul, and Ilja
