GarageSale 10 Beta 17 Released
GarageSale 10 Beta 17 is available for download from this URL:
https://downloads.iwascoding.com/downloads/GarageSale_10.0b17.dmg
What’s new in Beta 17
  • on first start, your data will be copied into a separate GarageSale 10 library (if you switch back to GS9, changes made there will not be visible in GS10 and vice versa. Also macOS will prompt you for your Keychain password for each of your eBay accounts, so GS 10 can access your saved eBay access tokens)
  • the shipping carriers popup now has a live filter field to narrow down the carrier list
  • fixed an issue with appending documents to listings (product safety)
  • improved error handling when updating quantities from the Variations panel
What’s new in Beta 12
  • switched to a new eBay API for uploading listing images to eBay’s Picture service (the API used by GS 9 is supposedly turned off in September)
  • fixed cosmetic glitch in Attributes panel for certain attribute types (eg. DVD > Region Code)
  • tweaked “package type” fix from Beta 10 to prevent unwanted eBay warnings in certain scenarios
What’s new in Beta 11
  • AI Generator window can be invoked for listings that are already running
  • Apple Script: store categories can be queried (see example script)
  • Apple Script: added ‘remove all item specifics from’ command (see example script)
  • Apple Script: added ‘add required item specifics to’ command (see example script)
  • Apple Script: added ‘add suggested item specifics to’ command (see example script)
  • Apple Script: fixed errors when trying to change a listing immediately that was just duplicated
  • updated French and Italian localizations
  • crash fixes
What’s new in Beta 10
  • always send the package type to eBay when staring listings, so shipping profiles using calculated shipping don’t fail with “Package Type is missing”
What’s new in Beta 9
  • styled text can be pasted into the attributes in the Preview (formatting is not yet removed)
What’s new in Beta 8
  • Variations panel: adopted new eBay API to make “Update Remaining Quantities” button work with listing with more than 200 variations
  • Orders section: adopted a new eBay API to download a buyer’s registration address (may only work in specific countries)
  • Scheduler Groups: listings removed from a scheduler group that’s currently processing aren’t started
  • Scheduler Groups: changes to launch interval and start times are applied to already running upload operations
  • Scheduler Groups: when deactivating a group with pending listings, yet unlisted listings aren’t started
  • Scheduler Groups: GarageSale no longer hangs when erasing interval field
  • Scheduler Groups: added ‘seconds’ label to interval field
  • updated GarageSale Icon Legend
  • added “Item Overview” print template to Print Pick List menu
  • updated Localizations (not fully complete yet)
What’s new in Beta 7
  • added more logging to track down specific issues
What’s new in Beta 6
  • fixed a bug, that when pasting images into multiple listings at once, could cause errors when executing some AppleScripts later on
  • GarageSale’s application icon of beta version contain “Beta” marker once again
What’s new in Beta 5
  • added “Print Pick List” feature to Listing section (like Packing Slips for orders, but for listings)
What’s new in Beta 4
What’s new in Beta 3
  • new application and document icons
  • new preferences setting: “Outline View: Show Recursive Item Count”
What’s new in Beta 2
  • Orders section: users can increase thumbnail size in the item table via context menu
  • some tweaks to ‘Send Offer To Buyers’ window positioning
  • uses new eBay API for downloading certain category attributes
What’s new in GarageSale 10
Kristian, Paul, and Ilja
