The fourth beta version of GarageSale 7.0.10 is available for you to download from the URL below, or the built-in updater if you are already running a previous beta version.
https://downloads.iwascoding.com/downloads/GarageSale_7.0.10b4.dmg
- improved performance when writing to changes to disk
- updated localisation in French and Italian
What’s new in GarageSale 7.0.10
- when a design adds a link to your eBay store in your listing, that link is now an HTTPS link
- the ‘Repair Image Links’ command now converts HTTP URL images to HTTPS, too
- ‘Live’ mode prevents spam ads on eBay’s View Item page from opening external browsers
- fixed a problem setting the zip code for calculated shipping via AppleScript
- added an example AppleScript to change the BuyItNow price of the selected listings by a certain percentage
- fixed an issue with the ‘Cross Stripes’ design that led to a display issue in Preview mode
- hopefully fixed a problem on macOS 10.13 where an entered license code was not saved
- URL-images imported using the ‘Import from My eBay’ command are now prefixed with HTTPS if they are stored on the eBay Picture Service (EPS)
- reduced memory footprint when using the ‘Repair Image Links’ on a large number of listings
- added a ‘Show Listing’ context menu command to the errors and warnings view when starting or verifying listings
- when warnings are received from eBay, ‘Suggestions received’ is shown in the error view instead of ‘No problems found’
- the ‘Add URL Image’ command will now warn if the added images does not exist or does not use HTTPS
- before starting a listing on eBay, GarageSale will check if all url-based images are using HTTPs
- changes to the category data loading mechanism
- crash fixes
