The second beta version of GarageSale 7.0.16 is available for you to download from the URL below:
https://downloads.iwascoding.com/downloads/GarageSale_7.0.16b2.dmg
- adds workaround for invalid URLs to eBay store received by eBay’s API
- fixed a bug in the variations panel that could cause image information to be lost when deleting columns
What’s new in GarageSale 7.0.16
- spinning progress indicator is shown again while searching
- the “Open image in External Editor” detects file changes more reliably
- only shows return policy description text box, if this option is supported on the selected site
- only sends return policy description in AddItemRequest, if this option is supported on the selected site
- added ‘useGlobalShipping’ tag to xml import file format tag
- fixes glitches in variations panel on upcoming macOS Mojave
- state of “automcomplete tags” context menu option in Markdown mode is saved to prefs
- no longer quits when app is hidden during listing launch and auto-close launch window option is set
- fixed crash when “Reveal Original” was invoked on orphaned item in a smart group
