GarageSale 7.0.6 Beta 2 released
GarageSale 7.0.6 Beta 2 is available for you to download from this URL:
https://downloads.iwascoding.com/downloads/GarageSale_7.0.6b2.dmg
What’s new in this Beta version
  • on startup, GarageSale selects the items that were last selected
  • double-clicking an image in preview mode will now open the built-in editor
  • added smart group rules for ‘auto restart’ and ‘did use auto-restart’
  • clicking the ’paid’ checkbox for orders or transactions is now reflected on eBay
  • shows warning when ‘paid’ or ‘shipped’ checkbox changes cannot be uploaded to eBay because there’s no internet connection
  • Best offer: auto accept and auto decline field can contain the same value without raising an error
  • image context menu in inventory section works again
  • when uploading listings, url-based images sourced from linked inventory items are handled correctly
  • source list select and shows newly created items again
  • Image Editor: filters are no longer applied to crop mask
What’s new in GarageSale 7.0.6
  • built-in image editor can be zoomed and scrolled
  • various crash fixes
I will give it a try…
@ilja which is the difference between “autorestartenabled” and “diduseautorestart”? I am still having many troubles with auto-restart feature…
I have just set a smart group as “autorestartenabled is yes + status is ended without success”. It says there are only 11 listings, however I have hundreds that have auto-restart enabled but are expired without any reason, look the screenshot…
Is there anyone who can explain me why these listings are expired?? There are no red warnings in advanced tab… I am afraid I will give up using relisting :unamused:
It does not work for me…
@ilja is it possible to set the smart group in order to group only listing with auto-restart enabled that are not relisted because of some problem (red warning error in advanced tab)?
  • “Auto restart enabled” -> an listing, whose auto-relist checkbox is enabled. Current versions of GarageSale turn off this check box, so you should mostly see active listings in there
  • “Did use auto-restart” -> a listing, which previously had the auto-relist checkbox enabled, and was already used to start a new listing from
I don’t think that such a smart group makes sense, as we turn off the auto-relist checkbox once it has been used for an ended listing.
Can you for a few of those listings, when they ended? Just recently or a few weeks ago?
Which layout and design are you using?
Probably yes. Let me look into this.
Mmmh this sounds complicated… @ilja I don’t understand what you mean saying that “Current versions of GarageSale turn off this check box”. Is it a bug? Does GS turn it off although it is enabled? Or what else?
If I start a listing with auto-restart enabled and it expires, then it is obviously autorelisted and the new one still has the box checked, does’t it? If so, I don’t understand why [quote=“ilja, post:6, topic:2332”]
[/quote]
Concerning this
I need to know which listing were not relisted because of some problem (it is generally marked by a red icon in advanced tab of inspector)…
Uhm what do you mean :cold_sweat: what can I… ? It was the day when I reported it, so about one week ago…
Pro: Urban with some modifies
Thank you!!
