The fourth beta release of GarageSale 7.0.8 is available for you to download from the URL below, or from the built-in updater if you are running a previous beta version:
https://downloads.iwascoding.com/downloads/GarageSale_7.0.8b4.dmg
- fixed an issue where listing changes that were made in search mode weren’t saved
What’s new in GarageSale 7.0.8
- the image context menu in editor mode now shows the image’s dimensions
- updated ‘Icon Legend’ in the Help menu
- added support for a different flavour of eBay TurboLister CSV files
- remembers the time interval you last selected in the built-in scheduler and uses it for new events
- will display a local error when user enabled eBay’s ‘Global Shipping Program’, but lists in a category where GSP is not supported
- addresses a crash during outline view manipulation (e.g. duplication or re-listing) under low memory conditions
- fixed crash when trying to end a listing, for which GarageSale does not have account information
- fixed an issue when verifying your PayPal API signature
- fixed an issue where the ‘Download images’ flag in the ‘My eBay Import’ panel was ignored
- fixed a problem which caused not all charity organisations supported by eBay to appear
- fixed a bug that caused the launch control window to close when listings were uploaded by a background task
- no longer shows duplicate error panels when entering incorrect numbers into value fields in the inspector
- a few documented commands in GarageSale’s built-in design language didn’t work. This has been fixed
- improved error handling when listings from GarageSale 6 fail to import
- added repair mode to relocate listings that are no longer present in GarageSale’s current group hierarchy (hold down control key on app start to enable it, checking your database can take several minutes)
- fixed a rare problem that could occur when a buyer ordered items from the same listing in two or more transactions with a single eBay order
really???
