Beta 35 of GarageSale 7 is available for you to download from this URL (or by using the built-in updater if you are already running an earlier beta version GS 7):
https://downloads.iwascoding.com/downloads/GarageSale_7.0b35.zip
- listing validation is not triggered by changing an event’s start date or removing a listing from an event in the Scheduler window
- package dimensions can be specified in the Shipping panel if a shipping policy is selected
- the “Remove category after duplication” preference works now
- the outline view in Orders mode shows the number of additionally purchased items when preferences are set to show buyer name instead of listing name. Previously this number was only shown when the preference was set to show the purchased item’s title.
- improved German localization
What’s new in GarageSale 7
- much more
Upgrades and Pricing
Migrating from GarageSale 6
- Quit GarageSale 7
- Restart GarageSale 7
What’s still missing
- a user manual
