Beta 4 of GarageSale 7 is available for you to download from this URL (or by using the built-in updater if you are already running an earlier beta version GS 7):
https://downloads.iwascoding.com/downloads/GarageSale_7.0b4.zip
- item attributes required by eBay can now be specified in variations without triggering errors
- when changing the search field, so that the search result goes from non-empty to empty, the user interface is updated properly
- disabled JavaScript for the live listing web view to prevent annoying eBay advertisement popups
- when exporting a single listing, the save panel is pre-populated with the listing’s name
What’s new in GarageSale 7
- support for barcodes for on the variation level
- much more
Upgrades and Pricing
Migrating from GarageSale 6
Where does GarageSale 7 store it’s data
~/Library/Containers/com.iwascoding.garagesale7/Data/Library/Application Support/GarageSale
You can go to this folder by choosing “Show Library Folder” from the “Help” menu.
What’s still missing
- a user manual
