GarageSale 7 Beta 9 Released
Beta 9 of GarageSale 7 is available for you to download from this URL (or by using the built-in updater if you are already running an earlier beta version GS 7):
https://downloads.iwascoding.com/downloads/GarageSale_7.0b9.zip
  • bulk editing of listings attributes works, if the listings had no attributes before (thanks @icspanta)
  • the 'New listing from inventory item" command now adds all images from the inventory item to the new listing (thanks @Matthew_Olson)
  • the preview updates when you change the SKU of a listing to reflect changes in the linked inventory item’s images
  • some categories offered variations, even though they are not enabled by eBay. This has been fixed (thanks @MOMODIVE)
  • the title of the menu command changes, if a smart group is selected in the outline view
  • double clicking orders in the overview table works now
What’s new in GarageSale 7
  • much more
Upgrades and Pricing
Migrating from GarageSale 6
Where does GarageSale 7 store it’s data
~/Library/Containers/com.iwascoding.garagesale7/Data/Library/Application Support/GarageSale
You can go to this folder by choosing “Show Library Folder” from the “Help” menu.
What’s still missing
  • localized user interface for languages other than English
  • a user manual
  • CSV import for inventory items
  • XML import for listings
Will you be making it easier to select photos in the editor panel? Specifically using the shift and click method to select a group of the images and move them into a different order on the listing. Thanks.
I agree, the selection behavior in the images grid view is currently confusing.
Here’s the somewhat complicated back story:
In GarageSale 6 we used a custom grid view component, which put us in charge of how selection and other things worked. However, it was a few thousand lines of code we had to test and maintain ourselves.
So, for GarageSale 7 we decided to go with Apple’s grid view component. This component has some serious performance issue (notice the lag when selecting a (smart) group with 1000+ items), and shows a non-standard selection behavior. Unfortunately we discovered this only after we switched to Apple’s component.
However, there’s a new version of Apple’s grid view component available, that supposedly fixes performance and selection issues. We could switch over this newer grid view component, but only if we raised to minimum system requirement for GS 7 to OS X 10.11 or later, thus locking out a number of users.
As of now, we are still undecided what to do.
