GarageSale 8.1 Beta 10 is available for you to download from this link:
https://downloads.iwascoding.com/downloads/GarageSale_8.1b10.dmg
What’s new in Beta 10:
What’s new in Beta 9:
- updated German localization
What’s new in Beta 8:
What’s new in Beta 7:
What’s new in Beta 6:
What’s new in Beta 5:
What’s new in Beta 4:
What’s new in Beta 3:
What’s new in Beta 2:
What’s new in GarageSale 8.1:
The GarageSale team
