GarageSale 8.1 Beta 4 Released
GarageSale 8.1 Beta 4 is available for you to download from this link:
https://downloads.iwascoding.com/downloads/GarageSale_8.1b4.dmg
What’s new in Beta 4:
  • fixed bug where certain eBay orders would be repeatedly marked as “new”
  • Synching: GarageSale will warn users when synching with GarageSale 8.1 for the first time, that older GarageSale will no longer be able to access their synch accounts
What’s new in Beta 3:
  • improved startup performance, especially when a lot of listings where selected when GarageSale was last quit
  • fields for entering VIN and parts compatibility are immediately visible in the inspector when switching from Motors to non-Motors site
  • Preview: Character count in title field (listing design) now gets shrunk while typing
What’s new in Beta 2:
  • when revising a listing’s quantity on eBay, a warning is displayed if the new quantity exceeds the current quantity left
  • when using the “Update existing listings” during CSV or XML import, GarageSale can open the Revise panel for updated, running listings after the import is done
  • CSV Import panel remembers last used column configuration and window size
  • when using the “Update existing listings” during CSV or XML import, all listings with a matching SKU are updated
What’s new in GarageSale 8.1:
The GarageSale team
