GarageSale 8.1 Beta 5 is available for you to download from this link:
https://downloads.iwascoding.com/downloads/GarageSale_8.1b5.dmg
What’s new in Beta 5:
What’s new in Beta 4:
What’s new in Beta 3:
What’s new in Beta 2:
What’s new in GarageSale 8.1:
The GarageSale team
