The thirteenth beta version of GarageSale 9 is available for you to download from the link below:
https://downloads.iwascoding.com/downloads/GarageSale_9.0b13.dmg
What’s new in Beta 13
- the “Move Selection To” command now moves groups selected in the outline view, instead of the group’s content
- more performance improvements when selecting a larger number of items
What’s new in GarageSale 9
- run custom JavaScript to process listings in your library
- Launch control can show errors returned from custom JavaScript validation function
- main window toolbar is customizable
- reports: added ‘Total fee’
 Orders section: replaced “Feedback Left” checkbox with “Leave Feedback” button, when no feedback was left yet
- the new ‘tag’ property on listings is now accessible via AppleScript
- GarageSale’s Preferences window remembers it’s position
Synching
Licensing during Beta phase
Cost
- macOS 10.12 or later
