The fourteenth beta version of GarageSale 9 is available for you to download from the link below:
https://downloads.iwascoding.com/downloads/GarageSale_9.0b14.dmg
What’s new in Beta 14
- fixed quirks with determining the correct type of barcode (needs manual category update first)
- Order section: titles of listings can be searched for again (needs manual removal of GarageSale-FTSIndex.leveldb directory to work for existing orders)
- fixed UI glitches in Accounts window
- improvements to image download for missing orders
- updated German localization
What’s new in GarageSale 9
- run custom JavaScript to process listings in your library
- Launch control can show errors returned from custom JavaScript validation function
- main window toolbar is customizable
- reports: added ‘Total fee’
- the new ‘tag’ property on listings is now accessible via AppleScript
- GarageSale’s Preferences window remembers it’s position
- the “Move Selection To” command now moves groups selected in the outline view, instead of the group’s content
Synching
Licensing during Beta phase
Cost
- macOS 10.12 or later
I’ll check it.
