The second beta version of GarageSale 9 is available for you to download from the link below:
https://downloads.iwascoding.com/downloads/GarageSale_9.0b3.dmg
What’s new in Beta 3
- the ‘automatic restart’ feature will now properly queue re-list operations to prevent GarageSale from stalling
- fixed an issue where the Preview would remain empty
What’s new in GarageSale 9
- reports: added ‘Total fee’
Synching
Licensing during Beta phase
Cost
- macOS 10.12 or later
