Beta 12 of GarageSale 9.6 is now available for download from this URL:
https://downloads.iwascoding.com/downloads/GarageSale_9.6b12.dmg
What’s new in Beta 12
- the zip code from your listing’s location settings (‘Advanced’ tab in the Inspector) is now used for calculating shipping rates when using calculated shipping
What’s new in Beta 11
- added ‘Days Since Order Received’ smart group rule in the Orders section
What’s new in Beta 10
- added ‘order date’ as sorting option for order smart groups
- added ‘start time’ as sorting option for listing smart groups
- listing overview mode uses ‘eBay gallery’ image instead of listing’s first image
- fixed several ‘validate…’ commands for updating outline view context menu
What’s new in Beta 9
- fixes a crash occurring when several smart group rules with relative dates (e.g.days remaining, days since start) were combined in the same smart group
- fixed wrong title for “Delete Smart Groups” command when multiple smart groups are selected
What’s new in Beta 8
- empty smart groups can be duplicated
- additional fixes for new ‘Days Since Start’ smart group rule
What’s new in Beta 7
- smart groups can be duplicated
- added warning when deleting smart groups to prevent accidental deletion
- fixed ‘Bold’ button in Preview mode’s formatting toolbar
- improved check mark image in Lauch Control for better Dark Mode appearance
- fixed recognition of changed ‘reply to’-links in eBay Message to eBay GarageSale’s reply window
What’s new in Beta 6
- fixed bugs in the new 'Days Since Start" smart group features
What’s new in Beta 5
- added a new ‘Days Since Start’ smart group rule for listings
What’s new in Beta 4
- added ‘startDate’ to listing JavaScript commands (this time for real)
- fixed Dark Mode issues in JavaScript editor
What’s new in Beta 3
- Link Listing command: improved handling of listings with non-ascii characters in their title
- the ‘Apply current Changes from eBay’ command can import missing images from eBay
added ‘startDate’ to listing JavaScript commands- fixed a crash when using the ‘Paste’ command in the return policy panel
What’s new in Beta 2
What’s new in GarageSale 9.6
Kristian, Ilja, and Paul
