Dylan
February 17, 2018, 11:18pm
1
HI haven’t listed anything in a month or so, I open the app today, it says there was an update installed and to restart, I do and now my new listings look like this.
https://www.ebay.ca/itm/112821670557
The images look large like they used to in the preview, but once they are up they just look like this.
This is a listing I created a while ago
https://www.ebay.ca/itm/112497309150
Seems to me like a whole bunch of code is missing.
This is the new messed up image code I believe.
And this is all the old one that looked right.
.gs-descHasFrame #gs-garageSaleBadge {clear: none !important;}
.gs-descHasFrame #gs-descriptionFrame {margin-right: 38%; zoom: 1;}
.gs-descHasFrame #gs-imagesRight {width: 35%; padding-top: 0px;}
.gs-descHasFrame .gs-borderTop {float: none; text-align: center; width: 100%;}
.gs-descHasFrame #gs-imagesRight img {width: auto; _width: 100%; max-width: 100%;}
/ for IE6 ,7-8quirks: /
.gs-descHasFrame #gs-descriptionArea {} / _width: auto;/
/ for FF2 or older, Camino168: /
.gs-descHasFrame #gs-imagesRight img , x:-moz-any-link {width: 100%; max-width: 400px;}
.gs-descHasFrame #gs-imagesRight img , x:-moz-any-link, x:default {width: auto; _width: 100%; max-width: 100%;} / restore for Firefox 3.0 and newer, IE 6-7 /
/ ::::: if design has Image Area Frame ::::: /
.gs-hasImgAreaFrame .gs-borderTop {float: none; text-align: center; width: 100%;}
/ ::::: Captions ::::: */
#gs-imagesRight .gs-captionArea .captionText {max-width: 400px;}
Any ideas/help?
ilja
February 18, 2018, 3:55pm
2
Here is a version that addresses this problem. Please make sure the read the release notes to learn how to fix listings already running:
The first beta version of GarageSale 7.0.13 is available for you to download from the URL below, or the built-in updater if you are running an older beta version.
https://downloads.iwascoding.com/downloads/GarageSale_7.0.13b1.dmg
What’s new in GarageSale 7.0.13
This version addresses a change in eBay’s image upload server, that causes GarageSale to embedded low-resolution versions of your images into the listing’s description under certain circumstances.
Only users tha…
schwane
February 18, 2018, 9:45pm
3
This resolved the issue for me and fixed my current auctions, thank you. I’ll close my support ticket as well.
Regards,
Dave
Kathy
February 20, 2018, 8:48pm
4
I have the same problem and downloaded and installed the suggested update. But I have a problem following the directions to fix current listings. I got to #2 and found the directory “UploadedImages.leveldb” in the Help menu. But if I go to step #3 , I lose access to the Help file when I close Garage Sale, so I can no longer locate or delete the “UploadedImages.leveldb” directory. Please help - what am I missing? Thank you.
Hi Kathy,
please just download the second beta of GarageSale 7.0.13.
No manual deletion of files necessary anymore with this version.
GarageSale 7.0.13 Beta 2 is available for you to download from the URL below, or the built-in updater if you are running a previous beta version.
https://downloads.iwascoding.com/downloads/GarageSale_7.0.13b2.dmg
this version improves the fix for low resolution images embedded in your listing description. All you need to do know is to revise affected running listings to get them updated with high resolution images. No manual deletion of …
Hope this helps,
Kristian
Kathy
February 22, 2018, 2:04am
6
Works perfectly! Thank you!
system
Closed
March 4, 2018, 2:04am
7
