The manual available at https://manual.iwascoding.com/ seems to be offline (unknown host).
Hi Doc,
just tested it here in Safari and FireFox. In both browsers it works like a charm.
https://manual.iwascoding.com/gs7/en/
Can you please give it another try? Maybe it was just a temporary issue. Also you can always open the help offline through GarageSale’s Help menu!
Yes, sorry your right. It sems to be a problem within my corporate network. I’ll check with out IT :).
The domain manual.iwascoding.com is not available in the USA…
Can not ping, lookup, nor traceroute. See 3 following screenshots.
Hmm. That looks strange. What do you get if you do an “Whois” on manual.iwascoding.com ?
