Is it possible to move items from the RHS window using the drop down menu. Currently only available from the Edit Menu.
Is this the desired effect?
I selected all the items in the RH pane (a subset of the items in the group Mar) then Edit/Move from the Menu.
Surprisingly, at least to me, the whole group “Mar” was moved instead of the selected items.
The latest beta should be addressing this issue. Also, the “Move To Command” is now available from the “Overview mode” context menu.
