As the title says - this is probably considered too much of a nitpick, but if it is an easy fix, it would be appreciated.
I run 2 monitors and when I start listings, the GarageSale Launch Control window never remembers where I last placed it. It would be a bit handy if it did, as I am moving it out of the way so I can continue to work in GS while stuff is uploaded, but the window is visible [right now it pops up right on top of the main GS window, so if I click back into the main window, I would not be able to see the launch control window, so I am always dragging it to a spot on my other display].
In the latest beta of version 9.9.5, we made some changes. Unfortunately, the position is now restored on the main displays, but it still doesn’t work for multi-display setups. We’ll keep looking into a solution.
Wow! Thanks for the quick fix, even if for now it is limited to one monitor. I don’t run 4k monitors [they are 2560x1440], so I can’t fit too much on each screen, and tend to keep GS next to Bookpedia/SQLite Manager on one screen as those are my inventory/listing apps [bookpedia is used for inventory/order recording/exporting to other marketplaces, GS, obviously for ebay ].
It’s been a while since I ran GS on my laptop [so the sync will take a while to catch up ] but I may give the beta a try on that and see how it goes. With software [from any vendor], I am very conservative about updates - I’m still running GS 9.9.2 and macOS 14.7.5; will be moving to 14.8.1 at some point soonish, after an image is made - 14.7.5 and 14.7.6 broke /usr/bin/shortcuts so it no longer works which messed up a huge workflow for me; took me a while to find a workaround as the 14.7.4 version was not in my Time Machine backup - https://vjl.li/wjvpt ]. If a big company like Apple can break things, I know it’s possible for any company to [though indie developers tend to be a lot quicker to fix things than Apple is!].
Anyway, thanks very much for this nitpicky bug fix. Much appreciated. I may unplug 1 of my monitors or check the laptop out to see if 9.9.5 or versions after the one I have] fix that very weird scheduler scrolling bug that I really need to make a short video of [I found a clear way to reproduce it, and know when it won’t happen, which hopefully helps, but it is a minor thing and again, may have to do with using 2 monitors]. Anyway, thanks again, and again.
