Problem with the 'Move To...' Command
Step 1. Perform a search for an item.
Step 2. Select item found.
Step 3. Select the group in which the item is located.
Step 4. Select ‘Move’ the group to somewhere.
Step 5. GS hangs and has to be shutdown with a Force Quit.
It was happening before the ‘Scroll to new destination’ checkbox was added.
I was able to reproduce this. It only happens if you are still in search mode and then try to move a whole group, right?
Correct, Kristian.
Beta 4 of GS 9.9.5 should fix this:
