Same Problem v9.4.1
Continuing the discussion from Verifies multiple listings but then gray box to submit: I’ve just upgraded from v9.3 to 9.4.1 and I’m having this Issue. After Verification of Selected Listings, grayed options to start listings or Cancel
Captura de pantalla 2023-09-17 a las 19.46.47
Just Solved !
After finding one of your suggestions to fix this issue: check if the “Run only local verification in Lauch control window” option
It was unchecked and now it’s running again.
