Searching Orders by a “partial title” does not seem to work. Searching Listings DOES work just fine.
Example #1:
Photo #1: Search a Listing by partial to find result. Also shows the Order in the upper right of the Orders pane.
Photo #2: Change to Orders and search again. Nothing.
Photo #3: Shows orders search popup menu options
Switch back to the Listings tab, and click the Blue Arrow in the Orders pane.
Photo #4: Shows the correct existing Order in the Orders tab.
Example #2:
Photo #5: Search again by partial title in listings
Photo #6: Click the Blue Arrow to goto the Order
Photo #7: Select the Search field, and hit return key to search. Nothing.
Photo #8: Search popup menu options.
Example #3:
Photo #9: Search again by partial title in listings
Switch to Order tab
Photo #10: Select the Search field, and hit return key to search. This time it shows some Orders…
