Shipping Carrier Question
Running 9.9.1 (1710) GS version.
Under Orders/Carrier there are many shipping carrier options. I only use a very few.
Is there a way to select the few I use as favorites?
Or exclude the ones I don’t use?
Or make the ones I use the most bubble to the top?
If not, is this a feature that may be targeted in the future?
Thanks
-les
When you open the selection window where all the options are listed, scroll to the bottom. The last item is ‘Show/Hide Services’. You can narrow down the selections there.
At the moment, this ‘Hide/show’ function is only available for the shipping options in Listing mode. @les was referring to the Carrier menu in Order mode where currently is no way to hide specific options.
Thank you. If there is a “request” listing somewhere, please add this as a feature request from me. -les
Here you go:
