Shows sum of BIN prices in overview mode v9.9.1b2 (1708)
Unicode currency symbol at the end ?
BIN Amount: 57.85 ¤
And if last digit is a Zero it doesn’t display it.
BIN Amount: 35.9 ¤
Very useful feature.
Many Thanks.
What currency are you using? GBP?
This issue is most likely fixed in the last beta version:
Many thanks all fixed in b3, yes was GBP.
As mentioned useful feature been waiting for.
Thanks.
