Smart Group Tile Option
Is it possible to have a “Title” “Does not Contain” option?
Literally was trying to do this earlier this week with SKU (a String). Seconded, but for all String-valued fields!
Thanks Bill
My problem is I want to search for the dog type ‘bulldog’ but I cannot separate out the football team ‘the bulldogs’
Regards David
0404499979
Vaguery
November 16
Can you maybe use the “Advanced Smart Group Options” to create a kind of “does not contain” rule?
Please see the section “Advanced Smart Group Options” here:
https://manual.iwascoding.com/gs8/en/Getting_Started-Groups_and_Smart_Groups.html#advanced-smart-group-options
I am learning everyday. Worked a treat Kristian. I must admit I was not aware of this extra function.
Or maybe I was but I had forgotten it.
Check out my posting from a couple years ago…
Smart Group Title Does NOT Contain - SOLUTION!
https://help.iwascoding.com/t/smart-group-title-does-not-contain-solution/6683
Thanks Neal. I actually remember your post and thinking I must store that away in the grey matter. And one year on……
