When I enter UPC code into the barcode field I am getting a Warning. I can ignore it and list my products without UPC codes and the product then appears with UPC codes. But why am I getting a warning?
mathis
June 21, 2015, 10:32am
#2
this i the same issue encountered in this thread:
Hi David, I have uploaded a pre-release for you here: http://downloads.iwascoding.com/downloads/GarageSale_6_2015-06-18.zip Please note that you have to update your categories in the preferences (even if it states that it is already up to date). With this release you will still get the warning about the not found product, but you should be able to upload listings without a EAN/ISBN/UPC to categories that requires a product identifier. The “Does not Apply” is automatically set on those item…
Please try out the link to the prerelease in the last posting. And report back whether this resolves your issue.
Mathis
