In this newest beta version, when selecting multiple items in the left pane list, the center pane seems to have “lost/forgotten” my center pane column selections and column order.
Actually, it is just not reading/using my changes/preferences. If I go back to the previous beta build, the correct columns and format is still being shown. 7.0.16b2 works, 7.0.16b3 does not work.
Any other preferences/Setting that might not be read/used correctly in this latest build???
Thank you for the continuous improvement of the Software.
Using a previous version of GarageSale 7.0.x, which are the necessary steps to upgrade whilst keeping the database?
Could you please add a small chapter “Upgrading GarageSale” in the “Installation and Setup” section of the manual, telling which steps are necessary in the case of upgrades between minor versions, with these two scenarios:
upgrade from 7.0.m to 7.0.n
upgrade from 7.x.* to 7.y.*
Is a payment required when upgrading between minor versions?
There are no special steps required. Just run the new version. You can switch back to a previous version in the same series without expecting problems.
No, we would have explicitly told you, if a payment would have been required.
“are those changes preserved after a restart?”
Yes, Strange. I’m afraid to try it…
Just switching between the last 2 builds (b2+ and b3), and works or doesn’t work…
Also after switching back to the previous b2 build, I now get the “software update” dialog for the version b3 when I launch the b2 version. Not sure this has happened before for beta versions…
Thank you for your feedback.
There is a small typo in the update info. It should be corrected now.
You’re right, often the update dialog does not appear in beta versions. We just “turned a switch” so that the update dialog is shown for that beta version.
Well… I did a bit more investigating of this issue…
I started with b2 (and only 6 columns showing in different sizes and different order), and then did a upgrade to b3 through the “Check for Updates” menu command to upgrade.
And… The middle columns got reset to the default view.
So… I reconfigured the columns in b3. Quit and Relaunch b3 app and the column configuration stays. Good.
I then quit and launched b2. Columns look good in b2. Quit and Relaunch b3 app, and columns reset to defaults.
So… It appears that if I stay in b3 all is good.
But… “upgrading” from b2 to b3 will reset all column data, widths, column order, and columns selected to show.
So… Maybe the new b3 is saving a newer version of this window view configuration data and is deciding to reset everything to defaults when reading the preferences for a previous version??? Or b2 is saving a newer version and b3 can not read it???
