GarageSale 7.0.5 is available for you to download from this URL, or via the built-in updating mechanism:
https://downloads.iwascoding.com/downloads/GarageSale_7.0.5.zip
What’s new in GarageSale 7.0.5
- dragging and dropping images from the Photos app on macOS 10.12 Sierra works again
- Orders section: added menu command to show shipping address in Maps app
- Listing section: added image context menu command to import images directly from Camera
- fixed possible crash when items referenced by smart groups where no longer present in the database
- pressing the return key in “Edit Image URL” panel now closes the panel instead of inserting newline character into URL
- right clicking on placeholder image in listing preview now shows a context menu containing the “Add URL Image” command
- fixed a possible crash when computing variation quantities during auto-relist of a variation listing
- fixed a possible crash when opening the “Advanced” tab in the listings inspector
- initial switch to the “Advanced” tab should be much quicker now
- eBay messages created in GarageSale should now be send quicker if GarageSale is busy downloading other eBay data
- fixed a problem where a listing’s state wasn’t properly updated when eBay listing data was received
- added additional safeguards against too many listing being started during auto-relist
- product search now searches on the site of the selected listing instead of the default site selected in GarageSale’s preferences
- reports are now searchable by name
- preview automatically reloads when list of listing videos changes
- added a new preference setting to close “Launch Control” windows after listings are successfully started
- added German help
- downloads fewer messages from eBay’s message system
- fixed a problem with the order of dropped images in the listing section’s Editor mode
- downloads listing fees when a listing without fee information is selected
- fixed a problem retrieving the buyer name via AppleScript
- fixed a possible crash when deleting an eBay account
- the XML import no longer ignores digits after decimal point in currency fields when reading your XML files
- fixed selection issues when a listing was moved after it was started or (auto)-relisted
- the 'Duplicate" toolbar and context menu commands now work when displaying search results
- the ‘New Group’ command in the ‘File’ menu works (again)
but any resemblance is purely coincidental …
