Beta 13 of GarageSale 7 is available for you to download from this URL (or by using the built-in updater if you are already running an earlier beta version GS 7):
https://downloads.iwascoding.com/downloads/GarageSale_7.0b13.zip
- eBay messages can be deleted
- PayPal transactions can be deleted
- no longer imports deleted eBay messages or deleted PayPal transactions from GS 6 (*)
- when importing orders from GarageSale 6, newest orders are shown on top (*)
- item cost are imported from auction templates in your GarageSale 6 library (*)
- store category popup remembers selecting “None” instead of inserting a blank item
- improved performance when selecting multiple listings
(*) this change requires a re-import of your GarageSale 6 database. Please see below for instructions.
What’s new in GarageSale 7
- much more
Upgrades and Pricing
Migrating from GarageSale 6
- Export any listing you created in GarageSale 7
- Quit GarageSale 7
- Restart GarageSale (make sure you using beta 8)
- Import any listings you imported in step #1
What’s still missing
- a user manual
