Beta 18 of GarageSale 7 is available for you to download from this URL (or by using the built-in updater if you are already running an earlier beta version GS 7):
the “Import from My eBay” command now downloads large images from existing eBay listings (thanks @lancemoody)
fixed a bug introduced in Beta 17 that caused the “GTC” duration setting to be removed from selected listings (thanks @John_Hui)
What’s new in GarageSale 7
completely modernized interface with instant error reporting
a new custom database engine, which hopefully deals better with large amounts of data and allows us to adapt to eBay changes more quickly
GarageSale 7 does away with the template/auction differentiation - it only offers listings, which can either be running or not
a new Orders sections which shows information about purchased items and buyers
Reports can generate diagrams in addition to text tables
automatic update of eBay category information as needed
listing design are now optimized for mobile devices
local live validation of most eBay errors in new “Preflight” panel
listing images can be edit using image editing apps installed on your Mac and with image editing extensions
listing images can be copied and pasted between images
support for barcodes on the variation level
you can copy specific settings from one listing and paste them into other listings
added a preference setting ‘Load Flash’ to prevent Flash plugin crashes
inventory items can be exported and imported
you can now set the quantity of 'Good ‘til cancelled’ listings to zero to mark the item “out of stock” (you need to enable the ‘Out of Stock’ feature in your selling preferences on eBay’s website)
when selling cars on eBay Motors or eBay UK, there is no a dedicated field for the vehicle ID (VIM or VRM)
much more
GarageSale 7 requires OS X 10.10 or later
Upgrades and Pricing
Migrating from GarageSale 6
GarageSale 7 has a new application identifier and uses its on database and 'Application Support folders, so you can run it along side GS 6 without side-effects
it should import your GS 6 library and your accounts (this process may take a while upon first launch)
Export any listing you created in GarageSale 7
Quit GarageSale 7
Rename the folder at ‘Library/Containers/com.iwascoding.garagesale7’ in your home directory to something like ‘com.iwascoding.garagesale7-old’
Restart GarageSale
Import any listings you imported in step #1
What’s still missing
localized user interface for languages other than English
a user manual
fixes for yet undiscovered bugs
Confirming that eBay images are downloaded at full size. Thanks.
Wow. so many changes in GUI! What is the item beside the Start Button (Triangle with exclamation point)? I can highlight a single image and the feedback is $0.40 (currency–maybe listing fee?). If I highlight 4 images, it says “8”? What could this mean?
CRASHING BUG Does not seem to gracefully handle large selections. For instance, selecting about 1000 listings (in order to move them to a folder, for instance) may result in spinning beachball from which the app never recovers. Sometimes it works. Selecting large numbers of listings just to view them also exhibits this behavior. In any case, long delays after selecting many items.
Have we lost the ability to look at listings as just a single images? This was a very elegant way to look at listings. This is huge for us since downloading from ebay seems to produce duplicates that are very hard to spot. Duplicate listing are a big no no for eBay and being able see and eliminate them is important. The single image method was the best for this purpose.
I will explore further but #2 above is concerning.
That field shows either the current error count for the selected listings, or there are no errors the listing fees as computed by eBay. However, there’s a know bug where this field does not update the error count as you fix them in the selected listing.
When GarageSale is hanging, can you recored a “spin dump”. This post contains instructions on how get one:
Could you post a screenshot from GarageSale 6 that shows the feature you are talking about?
Is this happening for listings created via the “New Listing command”? Or listings you imported from GarageSale 6?
Yeah, that error count/cost thing is an odd item, isn’t it. It seems to take a very long time to calculate (if you highlight a lot of items), doesn’t have a pop tip to indicate its purpose, and suffers from a known bug?
I will attempt to capture a spin dump. We are using a rather beefy machine (for your information, Mac Pro, 5,1 32GB ram 3.33 6 core Xeon).
Here is a screen shot of the very useful image view of listings:
Yeah. the crashing/lockup is pretty consistent when selecting a lot of files (in this case just by selecting a folder that encloses a lot of items). I earlier put a spin dump in the wrong thread but here it is:
Sorry, but GarageSale 7 is still in the beta stage. We have to do a lot more bug fixing and polishing before we’ll reach final state, but we are slowly getting there.
We are referring to this view as “image overview”. The good news is that is still in GarageSale 7, the bad news is that we are using an Apple component in GarageSale 7, which performs so poorly under OS X 10.10, that we had to only enable the image overview on OS X 10.11 or above.
Understood about the beta status, just offering feedback.
In the hopes that this helps, here is the procedure that generates the lockup:
First understand that I have 1618 listings that were all downloaded from eBay. I have placed all those listings in a single folder “Old Listings”.
I also have a few smart folders (Active (40 listings) , Sold (15), Unsold (1522).
If I want to lock up Garage Sale, I can open it and simply select the “Old Listings”–beachball will spin and app is locked. Same result if I simply select the Unsold smart folder.
HOWEVER if I open Garage Sale and first select the Active Smart folder (with only 40 listings), the behavior is as expected and THEN if I select one of the mega folders, the app USUALLY works as expected (it still occasionally locks but not too often).
If you change the title of a listing, it doesn’t change in the top-right section of the scheduler. It does change on the list below.
If a template has errors during verification, then gets fixed, the preflight window won’t change to reflect this (at least not when the errors are related to attributes). I’m guessing this may be related to an issue you mentioned earlier with the warning sign.
I see you can now duplicate and start a listing in one step, but it still isn’t very elegant for relisting unsold items. It doesn’t work with the scheduler, it requires more template than necessary. I’d be happy to just use the “automatic restart” function if I could trust it to only activate when the item doesn’t sell.
Can you provide a specific error scenario where you see this happening? Also, for some panels the errors are only updated after the panel has been closed.
I wish eBay would keep us in the loop about this changes.
I did try closing the Preflight window, but when I retried verification it was the same.
So, it seems the window never changes unless I close and reopen GS 7. I just duplicated a listing and deleted all of the item attributes. When clicking the exclamation/warning next to attributes on the options pane, it works correctly. However, if I click on the button with the three dots (to the right of the “Start…” button) and select “Verify listing…” the Preflight window opens with old info. It’s still there even if I switch to another listing. From what I can tell, it only changes if shows up elsewhere with new data (like the warning next to attributes).
Where does one go to see an auction that has been posted to eBay but doesn’t have any bids yet? I would like to see how many watchers there are, for example, and what the eBay ID number is.
That’s interesting, because these are exactly the areas where we think we made GarageSale perform faster. We’ll do some measurements and see if B19 is slower for us, too.
When a listing is running, click on the “Live” tab in the main window’s toolbar. This will give you a different inspector view that shows bids, watchers, etc.
I use a lot of groups and often have to change the variations of the listing.
When I select large GS folders freezes and remains in charge for a long long time, I have noticed that often at this stage using a large number of HD GB, I have 20 / 30GB free on my hard drive (SSD) and often takes me all of them and they are forced to close forcibly GS otherwise I freezes the whole system.
This also happened with the other beta.
Second:
I have 66 variants, when I update the entire listing, gives me a problem saying that variants are too many, but if I upgrade only variants everything works.
