GarageSale 8.1 Beta 22 is available for you to download from this link:
https://downloads.iwascoding.com/downloads/GarageSale_8.1b22.dmg
What’s new in Beta 22
- updated Italian and French localizations
What’s new in Beta 21
- fixed image re-ordering in Preview Mode
- fixed a bug with the new “Use remaining quantity” flag, that cause the new quantity to be set to zero
What’s new in Beta 20
- improved performance when uploading images to iwascoding image server
What’s new in Beta 19
- GarageSale now prefers ‘promised’ image file drags over plain drags, otherwise it would only receive low quality images from Apple’s Photos app
- images from inventory items can be uploaded again
What’s new in Beta 18
What’s new in Beta 17
- fixed crashes caused introduced while fixing issues with Service commands
What’s new in Beta 16
- macOS Service commands that write text into GarageSale should work again
What’s new in Beta 15
- improved error handling when image uploads fail
- macOS Services work again for extracting text selection from Listings mode
What’s new in Beta 14
- updated German localisation
What’s new in Beta 13:
What’s new in Beta 12:
What’s new in Beta 11:
What’s new in Beta 10:
What’s new in Beta 9:
- updated German localization
What’s new in Beta 8:
What’s new in Beta 7:
What’s new in Beta 6:
What’s new in Beta 5:
What’s new in Beta 4:
What’s new in Beta 3:
What’s new in Beta 2:
- when using the new “Update existing listings” option during CSV or XML import, GarageSale can open the Revise panel for updated, running listings after the import is done
What’s new in GarageSale 8.1:
The GarageSale team
