So far so good. Thank you so much.
You are a lifesaver. Thank you so very much for your prompt reply.
I’ve just signed up to this forum because Garagesale 6.9.7 crashes whenever I task it to revise a currently live auction. Although the auction did initially upload the eBay earlier this evening, the formatting of the photos is wrong - the thumbnail gallery of 6 images that shows on the template within Garagsale has uploaded as just the 1 image on eBay.
Many thanks,
Mark
Can you please check if there are any crash logs created in your home directory under Library/Logs/Diagnostic Reports that originate from GarageSale and post them here.
Ilja
Here’s the log file.
GarageSale_2015-11-22-115006_Marks-MacBook-Pro.wakeups_resource.diag.zip (24.2 KB)
There’s only a crash from GarageSale 6.8 in the file you sent.
That was the only one named Garagesale at the location you gave.
Will Console hold other relevant log files?
I also get constant crashes in El Capitan. All I have to do is bring up an existing template, and drag two or more additional photos to it from iPhoto. If I drag a single photo, no crash, but two or more does it every time. I have sent in several crash reports.
-Dave
What version of OS X and GarageSale are you using?
Can you reproduce the crash? Is there a crash report window coming up when you restart GarageSale? Please fill in your e-mail address in this panel and let me know the e-mail address you have been using. (You can use the private message feature on this forum to send it to me).
Garagesale: Version 6.9.7 (625)
OSX: 10.11.1 (15B42)
I would, but can’t find the private messaging feature! Where is it?
Simply click on Ilja’s icon. A menu will appear where you can click a “Message” button.
When I click on ilea’s icon, this is the pop-up I get, with no “Message” button:
Am I overlooking something obvious?
Thanks.
I can’t even get Garage Sale to open…
since the update to el capitan. I am running 6.9.7 from the with updates from ap store. Sure wold be grateful for a fix of some sort.
I think that’s another issue. You might want to have a look at this post for more details (and help) Garage sale hops around on bottom and not open - #31 by ilja
Ok, I deleted the app store thing and now 6.9.7 started up ok. However, it says it is (Demo Version) ? I was never asked to enter a license number - which I don’t have anyway - so will that be a problem?
