paul
1
GarageSale 9.8 Alpha 3 is now available for download from this URL:
https://downloads.iwascoding.com/downloads/GarageSale_9.8a3.dmg
- fixed crash on older macOS versions than 14.4
- switched to a new eBay API for product search (as the older one was deprecated)
- improved parsing of XML from the eBay API
- text blocks can contain macro language commands, like
[[item.title]]
- the macro command
[[item.conditionDescription]] is correctly expanded when used in the description
- the status of the toolbar item in the listing sections gets updated after ending a running listing
Kristian, Ilja, and Paul
Any chance you can address any of these items in v9.8???
Spelling and Grammar popup-menu checkmark options not saved for Title nor Description fields:
Start a running listing:
Wrong listing selected and hilighted after duplication:
Feature Request: Auto-Delete/Empty-Trash of Deleted Listings and Orders:
system
Closed
3
